My thinking that if 30 people rated a paint gun with a 9 and 3 gave it a bad score I would have to think it was a good paint gun. If 30 people gave a different paint gun an average rating of 3 and 3 other people gave it a 9 I wouldn't want to buy it. If only 3 or 4 people gave feedback and it was mixed then the jury would still be out. When I go to buy electronics I try to find ratings for products from actual buyers. Most of the time even if most people like a certain product you will have a few that hate it or don't like it very much. It was just a thought.
Danny |
The way I see it, paint guns are chosen for several reasons. Kind of like picking your mate. Everyone is looking for something different. Some people want something that is flashy, cost isn't really a factor, except thinking that more expensive is better. When they buy it, they adjust the gun the best that they can, then their technique is adjusted to the gun. Some people just want something that will spray paint and get a good finish, for as cheap as they can go, and throw it away when done. They too, adjust the technique to get the results. Then there are some that don't really want to spend alot, but want something that will last. They adjust their technique to fit what they get. You also will have some that just want something that they feel is comfortable in their hand. Again, they learn to adjust their technique to get the results.
The end results is that everyone will adjust to whatever gun they get,to get the results that they want. Alot will blame the gun for the bad results that they get along the way. On the other hand, if the gun could talk, they might be saying, "If you treated me right, I would have done right for you". So it's like, do you like a blonde, brunette, or redhead type of deal. Aaron |
What if you like blondes, brunettes, and redheads?
I am one that won't spend a huge amount on a spray gun. Been using cheaper guns for years with good results. The shops I worked in didn't have overly expensive guns either. This was before the iwatas and sata's that everyone seems to be talking about these days. My most expensive gun cost me over 200 a few years ago, and it is basically my base gun, a pressure feed hvlp. The cheapy guns I have do a better job of spraying clear. Just set up shop and spend huge amounts on paint and supplys, and your supplier will give you loaner guns to try, then you can see which gun you like the best. I suppose a rating thing might be nice, but like before its going to be basically opinions, and most people only have maybe a few guns to compare to each other, as far as what is good. Some may think a gun that they can lay down clear pretty flat and even is good since it can be wetsanded and buffed out, and any other minor imperfections in the paint job taken care of as well. Some won't be happy unless they can lay down a really flat finish and will want to do it with every clear they use. I don't see enough people getting involved with several guns to compare, and whos opinion is right. |
IMO, a painter that makes his living with these guns is your best source for good opinions. If a gun can't be setup to perform good he just isn't going to use it period. Primers aren't that critical-most cheapo guns will get your primer on just fine if the fluid tip is sized properly, basecoats usually aren't much of a challenge for most guns if the setup is right-metalics will identify how well the setup is and viscosity is usually thin enough that atomization really isn't a challenge. High solids clears on the other hand need a gun that'll break it up and transfer a consistant coat on the surface and some guns do have trouble with this reguardless of setup IMO.
| "Basic of Basics" Can I use "rattle can" paint on my car? | Centerline | Body - Exterior | 33 | 07-08-2011 12:33 PM |
| More on Orange Peel | KarKen | Body - Exterior | 36 | 03-22-2009 02:18 PM |
| why is my paint gun spitting? | a69446b | Body - Exterior | 12 | 02-20-2009 10:32 PM |
| Advice on paint gun for work | SilverFocusZX3 | Body - Exterior | 15 | 12-09-2005 08:21 PM |
| Paint Gun ? | Blaster | Body - Exterior | 2 | 06-29-2005 01:09 PM |
