I would sand the whole thing down to solid base paint w/ 320 wet-or-dry (keep the factory primer if at all possible), prime it in epoxy then build up a couple coats of poly sanding primer and block sand that w/ 400 for the final paint.
Thanks for the reply. That's the route I will go then, I can spray pretty decent but just don't know the proper steps and after my last painting incident I prefer to ask around here.
Thanks again |
strip it
Pretty bumbed currently, Jeep needs a new motor or crank so I kinda back burnerd it for a bit. Decided to go on and start on the paint and have been sanding as careful as I can but have went to bare metal in just a few small spots, lacking the knowledge on what my next step would be in terms of treating those areas I am once again asking for some guidance.
I have been sanding it with 320 on a da, working ok but like I said have hit metal in a few spots, trying to do this on a budget as best I can as I wasnt planning on 2k for a motor..sigh, thats how it goes at times huh... thanks edit: if it matters I am going with a SS black Last edited by Ducter; 02-11-2012 at 11:43 AM. |
If you are using an epoxy primer as your next step, don't worry about it.
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain |
on the dollar
yoh horny, first i been painting 32yrs. if u don't have enough primer just prime the spots then lightly sand off overspray by hand . you be better off sanding with 120 grite. 320 to fine you'll waste a ton of paper. ya i just blew the motor in my truck 61 yrs old i goofed. it happens just start over things will get better.
Alright...thank you all for the advice. I am finishing up sanding and getting ready for epoxy, its pretty cool here still though with 50-60s for highs and low to mid 30s for lows. I dont have a heated garage just use a propane heater to work out here when its cool. Most I have read on epoxy is it needs to be warm, the warmer the better. Given that am I pretty much screwed till we get warmer weather here?
I was going to paint it in a make shift booth with my propane heat getting blown in with duct work, exhausted out the back but with the epoxy, I would need to maintain a warmer temp for a few days right? Heres the deal with the Jeep, its going to be a daily driver thats going to see off road use. With that I am not real concerned about a top dollar finish but more so just have it all look decent enough. |
cold outside
man i've been threw all that. here's how i did it in the winter. i made a plastic paint booth . 12' x 30' TARP IN TOP AND ROLLED PLASTIC WALLS. with a fan blowing fumes outside. but not running fan for short peroids. cause it;ll suck all your heat out fast !!! get to know your paints. u'll know what u can get away with by temps. i shot a camro on on thanksgiving day no heat 27 degrees out. no heat !!! used centari with 151 high build lac primer. shot the whole car with primer. 2 coats of dupont centari hardner 793. sweetttt just go slow test paint on somethin if its real cool. u are getting very cold but with your plastic booth your heater should get it to 50. good luck take care gar
| Dupli Color Paint Shop auto paint Lacquer | ChevyTruckGuy | Body - Exterior | 227 | 04-25-2013 09:28 AM |
| The ultimate budget paint job thread /w pics (rustoleum paint) | Project89 | Hotrodding Basics | 130 | 04-24-2012 12:19 AM |
| Engine paint, high temp paint, Powerder coating??? | zbhover | Body - Exterior | 18 | 06-01-2011 07:16 PM |
| Sanding back my (less than awesome) first paint effort to paint again | Eric S | Body - Exterior | 5 | 04-11-2008 03:49 PM |
| base/clear paint for underside of vehicle or other paint? | hrc200x | Body - Exterior | 5 | 06-27-2007 09:55 AM |
