paint information
Has anyone used STARFIRE paint on their project? I found their site, and they have a good color choice,you can buy just the paint, or the kit-hardener,thinner,and paint combo pretty reasonably priced. They have acrylic enamel, and acrylic urethane. What are the plus or minus of either product? I would like to know about coversage, durability, any experience anyone has had with the product. thanks
| The Following User Says Thank You to kimman For This Useful Post: | ||
budlemon (07-11-2012) | ||
| The Following User Says Thank You to ortamenxs For This Useful Post: | ||
studeelover (07-10-2012) | ||
starfire paint
Thanks for the response. Sounds like you need a lot of experience to shoot this paint, and have it come out all right. I think I'll go with a more forgiving product. Thanks.
Ok I too am a newbie to painting and a bit confused with all the different paints. I think that I may want to use the acrylic enamel. Your response to ortamenxs’s question makes me feel as though you know your stuff.
I have a question. I don’t plan to paint it right away but need to protect it until then. What primer would you recommend to use with acrylic enamel? Chief |
You can get a very nice job with acrylic enamel if you have some experience. If you haven't shot too much paint it probably is not a good choice. You have to lay it down pretty heavy to get a nice gloss and it will slide, but if you don't get it on heavy enough you get an awful "dry spray" look that can't be fixed unless you sand and recoat. Urethane is by far the better choice even though it costs more. I never use cheaper paint because it's just to much work to prep for paint to take a chance. You might consider base clear. I shoot a lot of bikes and I won't use anything else. It is really not that much more than the others and face it, if your paint doesn't look good your project doesn't look good. Even if you have to save up a while longer to go with base clear it is worth it. Good luck with this deal. What ever you decide to go with follow the paint manufacturers recomendations TO THE LETTER! They have tech reference material that is great. You have to understand the manufacturer wants your job to come out right. I have been to several tech schools on paint and they spend a pile of money on R & D so you won't make mistakes. This includes using the proper reducers and hardeners for the temp and humidity etc.etc. Guys with experience can play with this but novices can't. I've got a lot of experience and I don't play with it. If I can help just holler.
| The Following User Says Thank You to DR327 For This Useful Post: | ||
chief36chevy (07-12-2012) | ||
Questions
This is great info. Some of my issues are.
1 I don’t have an expensive gun. It is a siphon type with a screw on cup. I bought it years ago and the last time I painted avehicle was about 25 years ago to paint a Datson pickup. At the time I was working at a Mack dealership and used Mack paint. I believe that it was manufactured by Kerker Chemical co. It turned out not all that bad. I have no idea what kind of paint it was but it looked ok considering what I started with. 2 I need to apply some body filler. Should I primer it first or apply the body filler(Rage Gold)? 3 There seems to be as many types of primers as there is paint. What would be a good primer to protect the metal until I am ready for painting if I go with acrylic enamel? 4 I have a good half mask, a home made paint booth made from plastic, and some box fans with some furnace filters. Any suggestions would be greatly appreciated. |
Happy to help
As far as a paint gun goes you really don't need expensive stuff. H.F. has a nice gravity feed non HVLP gun pretty cheap. HVLP is very nice, but it takes a bunch of compressor volume (not pressure) and most small compressors just wont keep up (6.5 cfm or so) so stay with a reg. gravity feed gun. Do your body work first and get it as slick and feathered as you can before you put on primer. If you prime with a urethane primer you should be OK for a while with out top coating. Urethane (or 2K primers as they are often called) do a nice job of sealing and filling so you don't get much shrink or die back. Again just be sure and follow the manufacturers directions (even on your filler) and you should be OK. When you get the gun pick up some cheap paint of some type (even hardware store enamel) and practice getting the reducer right. Years ago when I first started I painted some mailboxes, little red wagons, old bicycles and stuff for friends to get some good practice. Sometimes I even got paid for this. Not much but it helped pay for my practice paint. Just get your adjustments and gun technique down before you start on important stuff. DO NOT be afraid to put down some paint and always remember anything you screw up can be fixed. Good luck and if I can help just let me know.
chief36chevy (07-14-2012) | ||
Help!
DR327
Ok I ordered some polyurethane primer from Summit Racing. When it came the invoice said that urethane primer was not intended for bare metal, and that I should use epoxy primer first. So I ordered some epoxy primer. I cleaned most of the old Bondo, primer, and paint that was on the parts that I didn’t replace with new metal. I didn’t remove all of it as it seamed to be in good shape and was nice and straight so I thought what heck. I scuffed all surfaces with 120 grit, cleaned it down with alcohol, and then sprayed the epoxy. While the primer was still wet I noticed some bubbles along the edge of where the old Bondo and primer stopped. There was some Bondo and primer on the other panels and no bubbles. I am sure that I did something wrong. Should I have removed all the old Bondo and primer? Or should I have used a different cleaner than alcohol? Should I clean off the old Bondo and prime with epoxy? What should I use if while working the Bondo I expose bare metal? More epoxy or urethane? Sorry to be a pain it the A__. Thanks in advance. Chief |
Glad to help. Not a pain at all.
I really don't understand why they told you to use epoxy primer. I have used urethane primer a LOT on bare metal and NEVER had a problem. I may get people that don't agree, but if the bare metal is clean (I use #15230 Martin Senour wax and grease remover) I have not had a problem. Your alcohol may have bitten into your filler. I really don't know. Mix up a dab of your filler on a scrap piece and see what happens. I use an etch primer on aluminum for adhesion but only use it on metal if it is something (like a bike frame) that might get chipped or banged around during assembly. I have never used an epoxy primer therefore I have never had a chance to screw it up. Had I ever used it I probably would have and could tell you more about it. Any decent painter has screwed up a bunch. I will tell you what I would do now, but without seeing this deal this is tough to call. I would let the whole deal dry completely. Sand out the problems. If your sold on the epoxy put filler on a scrap panel and shoot a small spot. What I would not do is use alcohol to clean the panel. If you don't have a problem go ahead and shoot it. If you do have a problem with the test panel go ahead and shoot the job, urethane over bare metal and filler. You've worked hard on it. I really hope it turns out nice for you. Persistence will pay off.
| Paint Question #157 | rj57 | Body - Exterior | 5 | 10-31-2007 02:20 PM |
| "Basic of Basics" What kind of paint should I use? | Centerline | Body - Exterior | 5 | 10-21-2007 11:32 PM |
| what color to paint? | jum | Body - Exterior | 14 | 07-30-2006 12:29 PM |
| wax and grease remover | adrock430 | Body - Exterior | 14 | 07-30-2006 12:18 PM |
