Paint lifted with tape removal. Metallic BC/CC - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-21-2012, 01:36 PM
67Elcamino's Avatar
I finished laying my base and first coat of clear and when I took of the tape to trim off the door jambs (that I had painted 6 months aga) it also lifted some of the exterior paint. The tape was pretty stuck on there since its been on well over 5 months. I used 3m blue tape. My concern is if my sealer coat promoting enough adhesion to my base? or if tape stuck this well on paint it will lift it? I used HOK ko-Seal sealer under my base but shot it a week prior and maroon scuffed it the day I shot the base. If it didnt adhere right im going to be really pissed because I went through hell getting the Ko-seal sealer that HOK recommends for their metallic basecoat.
What would be the best way to fix? should I just brush some metallic? I know it might sound crazy but maybe its better to have a small line of a different shade of metallic that a 2-3 inch spot that differs from the rest of the car. I had a hell of a time shooting this metallic without tiger striping.
Old 05-21-2012, 07:21 PM
If the paint that you lifted was inside the door jam, you might try to do the brush touchup thing, depends on who you're doing it for. But if this is on the exterior of the car, forget it. You should feather it back until it stops peeling, prime it and paint it again. You may be able to break the spot on a body line or a peak by using the back masking technique. Also, stick your tape to your pants before you stick it to the car, it will help stop further peeling.
This used to just make me sick when it happened to a custom paint job, I know how you feel.
Dave.
Old 05-21-2012, 07:48 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Now you know if you leave tape on it seems to weld itself to the paint..
Sam
Old 05-22-2012, 08:22 AM
boatbob2
Tape..
The 3 M Blue tape is great,BUT its NOT supposed to be left on for 5 months,1 or 2 weeks,OK,more time needed,REMOVE the tape.
Old 05-22-2012, 08:51 AM
With tape left on for 5 months, all bets are off. There is no way you can judge how the sealer works or anything if you are leaving tape on for 5 months. There is nothing that is going compare with that in the normal world.
Old 05-22-2012, 10:09 AM
67Elcamino's Avatar
Thanks guys.. Yeah I figured I should of had that tape off right away and retaped again. I figured it was garage kept all that time and the tape wasnt exposed to sun that it would stick as bad. Also was trying to cut some corners cause I got my wife on my back about finishing the car.. LOL but thats for another conversation.
Another question;
Does the paint get harder over time? two days after I painted the car my buddy was helping me put on the hood, I dropped a 9/16 bolt on the corner of the fender and chipped the paint. The clear, base, and sealer,chipped off.
also dropped the bolt from about 12 inches above.
Old 05-22-2012, 10:20 AM
Ewww, that doesn't sound good. Yes it will get harder over a few days but coming off all the way with the sealer, that doesn't sound good. But listen, don't sweat over it, nothing is going to change it. If it chips easy, so be it. Next time do it differently. What if anything you did wrong I don't know. Don't sweat it, and drive with a smile on your face.
fresh paint outside tape removed atichargr Body - Exterior 7 09-07-2009 07:17 PM
moulding tape removal junior stocker Body - Exterior 8 01-09-2009 08:48 AM
Dummy Newb Q--Can I get metallic paint without the metallic? superkaz661 Body - Exterior 4 10-07-2008 04:16 PM
Metallic Re-paint bruce-77346 Body - Exterior 1 06-20-2003 08:23 PM
getting double stick tape off of paint Jag Daddy Body - Exterior 6 05-20-2003 04:51 AM
