Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Paint match Q
Thread: Paint match Q
Old 03-20-2013, 11:06 PM
Spray Machine Spray Machine is offline
The biggest problem with the cameras is finding a spot on the car that is perfectly flat. Almost impossible to find places on a car that are not convex, concave, curved/rounded to some degree. If you can find a flat spot the cameras will generally give you a blendable match. If your trying to take a read off a spot that isn't perfect it will read incorrectly, outside light getting in the exposure cause by not sitting perfectly flat at a 90 degree angle will affect the scan. Trunk lids, roofs, hoods that appear more or less flat have some degree of curve. The more curved the surface the more incorrect the scan will be. Also the camera must be absolutely dead still when reading. Even the tiniest vibration/movement will kill a read, nearly impossible to do when you have to hold the camera in your hands, they really need a remote to activate the camera to eliminate hand shake and need the manufacturers to make a perfectly flat spot somewhere on every vehicle. Its like a camera with a slow shutter speed, if not held perfectly still the 'picture' it takes/reads/scans will be blurred, it cannot focus on the type,size and reflective properties of the metallics in the surface your trying to read. No good for scanning tri-coats. If you really want to mess with the cameras mind scan a chrome bumper or a window!
