Paint matching? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 08-02-2009, 10:07 PM
Try my method. You'll find it works better.
  #17 (permalink)
Old 08-02-2009, 10:10 PM
Tomlowe523's Avatar
I will, I assume the blending solvent at paint store is a replacement for using reducer for blending. Is it better?
  #18 (permalink)
Old 08-02-2009, 10:17 PM
Maybe. I've been blending before those products came out and see no need to add additional expenses or inventory. Although, the prices of what I do use tend to go up regardless.
  #19 (permalink)
Old 08-02-2009, 10:22 PM
Just an additional note. I don't use reducer at all. I use dupont 3661S with everything I finish coat. Fast dry thinner (any brand available) for primers and 2K. Again, I keep expenses and inventory down.
  #20 (permalink)
Tomlowe523's Avatar
Thank you for clearing that up, I probably would have done that wrong for years to come.
  #21 (permalink)
Old 08-03-2009, 01:28 AM
deadbodyman's Avatar
Wiki Edits: 11
Originally Posted by cjperotti
Have to agree with Vince here. The jobber can only bring you so far. The unknown variable is the painter. Using a cheap or improperly maintained gun, not mixing the paint properly (especially metallic’s), or adding an additive can all singularly or collectively result in poor color match.
I have to agree also... but I think your looking for a "rattle can" solution ,right? so at the paint shop they can mix you up a pint and you can put it in a co2 paint sprayer "reuseable rattle can" to get what your after...dont try your first blend without a pro there to literally hold your hand to show the technique we use
  #22 (permalink)
Old 08-03-2009, 05:26 AM
I would like to thank you all again, it looks like I can get close which is all I'm looking for at this time. I have several projects going on at the same time and not enough money, LOL! Anybody have any suggestions to fix that?
Thank again
  #23 (permalink)
Old 08-03-2009, 03:13 PM
i think tom means clear base not clear coat
i have seen this done too looks ok i have just never tried it
tommy
The paint did not harden powerrodsmike Body - Exterior 27 03-05-2009 05:34 PM
"Basic of Basics" What kind of paint should I use? Centerline Body - Exterior 5 10-21-2007 11:32 PM
what color to paint? jum Body - Exterior 14 07-30-2006 12:29 PM
