Paint over Chrome - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-30-2009, 11:00 PM
Paint over Chrome
I have a set of Chrome Wheels that I want to Paint to match my Vehicle.
I am unsure if I should use an etching primer or epoxy before a urethane primer. What proceedure would anyone recommend?
I was going to try teh following:
- scuff chrome with 120-180 grit sanding sponge
- etch prime (Varaprime 615S)- 1 coat
- urathane prime (PPG k36)- 2 coats
- sand 600grit
- basecoat (PPG Evirobase HP) - 3 coats
- Clearcoat (PPG DC3000 or Dc4000) 2-3 coats
Any thoughts on my procedure? What if I need to use of polyfill (or other)... will this cause a problem if I apply an etching over it.
Thanks, Scott
Old 05-01-2009, 01:09 AM
Wiki Edits: 27
it's been a while
they used to sell a primer to use over chrome ,,, because of enviromental regulations a lot of paint has changed since i did that.
Paint over Chrome austin Body - Exterior 3 05-01-2009 01:37 AM
The paint did not harden powerrodsmike Body - Exterior 27 03-05-2009 06:34 PM
Painting roof tips needed..... Bluepen Body - Exterior 7 09-10-2005 10:26 PM
This is interesting. Temporary peel off paint. kenseth17 Body - Exterior 5 08-11-2005 10:41 PM
How do I correctly paint a chrome bumper? bukweet Body - Exterior 3 03-09-2003 08:26 PM
