I just finished painting my mustang with ppg shopline basecoat clearcoat and when I was wetsanding a small fiberglass side scoop I burnt through the paint. I decided to basically start over on it since it was a small piece. I sprayed a coat of epoxy primer and then got some lunch and came back about 2 hours later and sprayed it with a coat of basecoat color. After about 5 minutes I noticed that the paint was starting to pop badly. I've had this experience in other places where I sprayed basecoat over clearcoat (it's why I abandoned painting rally stripes on it for now) but the clearcoat had been dry for 2 days. I thought that would be plenty of time for me to be able to safely spray something over it considering the guy at the paint store told me 24 hours was adequate.
Am I even on the right track here with my thinking? Does it sound like the clearcoat is the problem?
FWIW, I had the same problem with clear that had been on a fender for at least three months, but stored indoors. The plan was to apply four more coats of clear, wet sand and buff. I sanded the original clear until all blemishes had been removed, used dx330 to clean. I then started applying the new clear. After the first coat had set for about 10 minutes I noticed lots of tiny holes developing in the newly applied clear. Barry of this forum diagnosed my problem as solvent pop. Seems even though the original clear had been applied for months, when I sanded it that allowed trapped solvent to leach out. His solution was to re sand then set the fender in the sun for a day and re shoot....problem solved. I know the "P" sheets say you can sand and re coat. My experience is that you need some time and heat to make sure the solvents from the original clear are gone.
Oh yah! A year would be plenty of time. The "key" you need to realize is wait some time after you sand it. A day or so should be plenty. When you knock off the top that allows more solvent to escape.
I'd use the 800. Just be careful on the edges and body-lines. Don't burn through the clear anywhere. Some of the guys say they use 400, but I won't recommend that myself, that just seems a bit coarse. Good luck with it! :thumbup:
Great to hear it! Maybe you could post some pics? :thumbup:
Related Threads
Hot Rod Forum
2.2M posts
175.7K members
Since 2001
