Paint or powdercoat? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-05-2007, 07:43 PM
tfeverfred's Avatar
Last journal entry: Black Dahlia pics
I'm building a bucket and I am thinking about powdercoating the suspension (front and rear). I have heard lots of feedback both pro and con. My thought is that considering how easy it is to breakdown the front or rear, painting would be the way to go (cheaper, I have way more time than money). I've also heard that powdercoat is more durable and would last a VERY long time. But if it does chip, you have to recoat it as it will look like crap if you try to touch it up.
Any opinions or experiences?
Old 03-05-2007, 08:57 PM
68RATVT's Avatar
Last journal entry: 46 Dodge frame
T,
I'm a firm believer in powder coating,it preserves the metal and is very tough. Can't reply to the chipping thing,have not hit it hard enough,just dents. I do antiques,projects,vehicle parts, I have a plow that was done 10-15 years ago,sits in the garden and looks new.Thing with coating is the prep work,use a good shop,yea they may cost 10% more than Bob down the street,but when it's time to bolt up,you don't want to file or sand.My block/heads/timing cover/oil pan/intake are there now,my bud calls me and says go get a gasket kit,the same kind you will be using for assembly and get it to him.Yes it was an extra 72 bucks,but now when it's done no bare metal will show and gaskets will fit great. It is significantly ore money to do,but man is it worth it. All the colors and textures are *****in...
Old 03-05-2007, 09:38 PM
Twisted Minis's Avatar
A different breed
Last journal entry: New Truck
I'm quite fond of the powdercoat option. My entire frame, front and rear suspension, axle housing, and a few misc. pieces are powdercoated. The price for everything really wasnt as bad as I expected. I've found that its incredibly easy to clean. You can clean it with carb cleaner or paint thinner if you wish, and it won't affect it unless left on for long periods of time.
It does however depend on the coating. There are interior and exterior coatings, of standard and industrial grades. Everything I got done in blue is an extrerior industrial coating. Its pretty stout. They can also lay down an epoxy filler coat first before the color to smooth everything out.
The "chrome" color is also very weak, very easy to chip, and is inconsistant in color. Silver is a slightly weaker color as well, but can be cleared and re baked for added strrangth.
Also, I happened to scuff my frame a bit while driving, and it left a dry spot, that looked as if it had been sanded down. I was able to buff it out and you cannot even tell it ever contacted anything. My frame also sits flat on the ground quite often, even when I start the truck, and I've had no problems yet.
So, powdercoat gets my vote. I can't say I'd ever paint my frame or suspension parts. Too easy to chip. Would you ever swing a ruber mallet at your nice painted suspension pieces? Probably not. But I didn't hesitate to give my powdercoated pieces a little persuasion.
Old 03-05-2007, 11:13 PM
willys36@aol.com's Avatar
Wiki Edits: 21
I vote for powder coating too. I coat everything that isn't sheet metal or chrome. Engines, heads, trannys (polished then clear coated), suspension and frames, fender wells, exhaust systems (everything but headers), you name it I coat it. I have never had a chip in 10 years and many cars. As the guys say above if it gets marred just color sand and polish and it's like new. For frames, the coating costs not all that much more than a commercial sand blast ot white metal which you need to do for a quality paint job anyway.
Old 03-05-2007, 11:52 PM
dinger's Avatar
powder coat it. One of the guy I know just had a complete 57 Nomad body p.c.ed. A tough foundation. Scuff it with coarse grit for bondo, he'll sand it lightly for paint. Just go some running boards back from p.c.ing, same thing there for body work, underside will be sealed with the toughest stuff ever, the powdercoat. not too bad to work with, of course most will not have to mess with bodywork when they get parts coated. My 36 Ford frame and chassis parts are coated, see my journal. Hard stuff to beat. Dan
Old 03-06-2007, 06:45 AM
tfeverfred's Avatar
First off I want to thank you guys for the input so far. It has given me a lot of food for thought.
Does anyone have experience with powder coat on a T bucket? Just about all the ones I have seen are painted and look fine or have they just redone the painting before a show or cruise. Any street rod guys with exposed suspension pieces have thoughts on this? How did they stand up under normal cruising?
The place I have found that I used on my wirewheels did a really great job, but while the price seemed fair, it took 2 weeks. Maybe I'm just putting too much thought into this, but I'm just seeking info on what will work best in the long run. It was no problem to paint and it only took a few days at minimal cost. I guess that is my main issue. Of course, if I am having to do it often, then that would be a plus in the direction of powder coating.
Old 03-06-2007, 07:50 AM
dinger's Avatar
Some coaters, depending on the size of the pieces, will accumalate enough pieces to make the job worthwhile. Sometimes a busier coater will get r done more quickly, they will have enough "gloss black" pieces to do a run right away. That's how my guy works it. I LIKE powdercoating. Dan
Old 03-06-2007, 09:27 AM
Well, I'll vote for powdercoating suspension stuff, too. I've painted that stuff before and it doesn't last like powdercoating. Of course, I powder coat at home. though. There's no wait, just finding the time to do it myself.
Old 03-06-2007, 03:17 PM
A different breed
It took only 2 weeks to have my frame, front suspension, rear suspension, and axle housing blasted and coated, and there was a 3 day delay on getting the color powder.
Old 03-06-2007, 06:47 PM
tfeverfred's Avatar
Thanks again for the advice. My rear suspension pieces will be here in about two weeks and by then i should have made up my mind. I'm leaning towards powder coating. It seems the way to go.
Thanks again for the input.
Old 03-10-2007, 01:18 PM
tfeverfred's Avatar
My gal! Today, I was taking her to work and she asked me how my T was coming. I explained to her my dilemma about going with paint or powder coating. I explained the benefits and cons of both. As we sat at a traffic light, she looks at me and says: "So, you can't decide how many times you want to tear down your car? Go with the one that will last the longest. The choice doesn't even sound like it should be a thought."
If I'm not careful, I may find myself on one knee one day.
Oh, and thanks again to everyone who gave advise and or comments. Sometimes ya just want to hear opinion, even when you already know what you need to do. You will, of course, understand that the one knee thing does NOT apply to you though. I just don't roll that way. Not that there's anything wrong with that.
Old 03-10-2007, 03:37 PM
Wiki Edits: 21
Don't want praise - just send money!!
Old 03-10-2007, 03:48 PM
tfeverfred's Avatar
She offered to split the cost with me.
Old 03-10-2007, 07:35 PM
Wiki Edits: 21
She sounds like a keeper. Better make an honest woman out of her quick!
Old 03-10-2007, 10:49 PM
tfeverfred's Avatar
I am. Probably this winter or next spring.
The paint did not harden powerrodsmike Body - Exterior 27 03-05-2009 05:34 PM
Paint Question #157 rj57 Body - Exterior 5 10-31-2007 02:20 PM
wax and grease remover adrock430 Body - Exterior 14 07-30-2006 12:18 PM
Paint or Powdercoat? buckethead1 Body - Exterior 6 04-13-2004 04:14 AM
