I can tell you that I use 80 grit on bare metal before applying epoxy primer. I finish filler work with 180 grit before applying HB primer. I use 320 before applying epoxy sealer. If I need to sand the sealer for nibs, I will usually use 600 or 800 wet.
Aaron |
Products
I will prob be using PPG or HOK. I am trying to get the best adhesion I can without seeing scratches under the base. I am painting over the factory paint. Same color but different shade. I want a white sealer under the yellow base I am using so that I get a very bright yellow finish. Is there a white sealer? I have been told to use white base as a sealer.
| paint gun | deuce_454 | Body - Exterior | 4 | 02-04-2004 04:08 PM |
| 38 year old paint unbelievably tough! Ideas? | GMW | Body - Exterior | 14 | 11-23-2003 08:54 AM |
| Paint choice? | daimon1054 | Body - Exterior | 2 | 10-29-2003 11:02 AM |
| 1st painting | nova33 | Body - Exterior | 19 | 06-16-2003 10:05 AM |
