paint problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-07-2006, 06:46 PM
paint problem
Sprayed nason thane . The trunk lid came out perfect,but when i srayed the final clear/paint the rest of the body was rough or gravel looking.so maybe i screwed up but wet sanded the bad with 1200 just to get the ugly off.I buffed it with meguires medium,fine then polish.It does not have the clear shine that the trunk has but it is slick.I know i can repaint but just wondering what happend
Old 02-07-2006, 07:14 PM
BarryK's Avatar
Maybe nothing happened!
Not sure your buffing experience but maybe you did not buff enough with your first or second step.
This is not uncommon and the best way to figure out is take the buffer to bottom of quarter and with the course cut hit it a couple of times in a one foot section and see if the gloss comes back. (it will)
There should be no reason to repaint and sounds like you just have not buffed the paint out enough.
Old 02-07-2006, 07:28 PM
Bee4Me's Avatar
Problem Child,Hard Case
Last journal entry: Strangest job I've ever done
I'm with Barry, What was your buffing procedure?
Might need to get a little more "ugly" off with some 1500 or go with a wool pad and some good ol' 3M Perfect-it II Fine cut rubbing compound.
Then a black waffle pad and some swirl remover. I don't think you got it "quite" buffed out yet.
Old 02-07-2006, 07:42 PM
paint problem
I sanded just right at the pit look of the paint. it is a cheap buffer.I think the rpm is around 2500.I could tell the difference between it and an air buffer.So go back to the medium cut and try it again.Will i have to buff the deck lid or should the rest come out and look the same?My understandung is clear is sort of yellow.The deck lid looks yellow compared to what has already been buffed.The color of the car is white.
Old 02-08-2006, 07:02 AM
Bee4Me's Avatar
497 isn't as "yellow" as some I've shot,it's really "clear" IMO. It's probly the fact that you mixed it in the Ful-Thane,or I assume that's what you did?
2500 is plenty fast for buffing paint. Usually between 1200-1800 is your max RPM especally with a wool pad and a solvent type compound. Cheaper buffers will slow down a bit with heavy pads but it should still be in a usuable range.
Old 02-09-2006, 07:00 AM
paint problem
Thanks for the info be4me and barryk.I wet sanded with 1500 and then buffed.The more i buffed the better it shined.It is really slick like a show car slick--looks good.
Old 02-09-2006, 11:44 AM
BarryK's Avatar
Thats great, the Nason is a pretty good single stage and as long as its a solid color you can buff to you have the gloss you want.
Old 02-09-2006, 08:40 PM
Bee4Me's Avatar
Cool!. So, How about a couple of pic's??
Old 02-11-2006, 08:05 PM
paint problems
10-4 bee4me.This is my weekend to work at the plant-the 12hr shift deal,so i will try to get a few pics mondayor tuesday on my days off.
what is the proper way to spray paint with a can? luckydevil Body - Exterior 19 01-07-2015 10:39 AM
Paint problem on 97 GMC racer7201 Body - Exterior 9 06-23-2009 11:14 PM
Looking to paint my car with OEM quality finish. Have some Questions Gro Harlem Body - Exterior 12 01-15-2005 06:31 AM
Rear window defogger................. poncho62 Electrical 2 01-05-2005 12:21 PM
please help..... annoying warm start problem 67cuda Engine 21 03-28-2003 05:44 AM
