Paint Problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-27-2005, 08:36 AM
Paint Problems
I have looked in as many knowledge and tech bases as I could and could not find information on why the paint is lifting off my car. It is a 1980 Vette. It started with a couple of bubbles on the nose and front fenders. Now there are numerous places and I am going to have the car repainted. I was told by a local shop that they may return after the car is repainted because it could be a problem with the fiberglass. I am not sure I buy into this because the problem is also on the nose of the car. The only affected areas are the nose and the front fenders. Help!
Old 03-27-2005, 12:13 PM
segge's Avatar
Welcome to the board . You would probably get some more replies and answers if you posted this in the body - exterior section, the guys there could probably help you out.
Old 03-27-2005, 12:39 PM
poncho62's Avatar
Wiki Edits: 5
moving it.....
BTW....that is a common Vette problem.....
Old 03-27-2005, 07:08 PM
You'll need to strip these areas down and remove/repair the problem. If you just sand the car and paint it they will for sure show up again. Fix the problem. Take the areas down with a sander and see what is there, the problem may be just under the paint or it may be in the glass but it will need to be corrected if you don't want it to come back. Bob
what is the proper way to spray paint with a can? luckydevil Body - Exterior 19 01-07-2015 10:39 AM
wax and grease remover adrock430 Body - Exterior 14 07-30-2006 12:18 PM
getting ready to paint hotrod66_57 Body - Exterior 3 02-08-2005 12:15 AM
Looking to paint my car with OEM quality finish. Have some Questions Gro Harlem Body - Exterior 12 01-15-2005 06:31 AM
Urgent paint Help 70chevy Body - Exterior 1 03-06-2004 06:26 PM
