Paint question
It's been a very long time since I was messing around with this hobby and now I have the bug again. My question is: Lacquer was once the paint of choice because of the very high shine possible with it. I know that a lot has changed in paint technology since those days. Is lacquer the still the way to go for a show quality shine or has something taken its place.
Thanks Y |
lacquer has a good shine, but BC/CC is more durable, longer lasting.. i like using deltron 1 stage acrylic urethane.
Yleefox, take note that 1 stage eurathane is not base coat/clear coat. It's a single stage that basically has the clear coat in the paint, like enamel paint. It's just a two part paint.
Base coat is easier to spray. The clear coat is a little harder to spray and it takes practise to get used to it. At least with clear coat, if you get a run or a sag, you can sand it out, buff and polish to a high gloss. Single stage metallics are NON-sandable. If you get a run or sag in it, you have to sand and reshoot. However, You can scuff single stage and shoot clear coat over it. The color sand, buff and polish to a super deep, high gloss finish. Frank |
The one thing
First off, thanks for all the replies. Secondly, one of the things I liked about lacquers, was the speed at which they dried. It was quick enough to make spraying in a home workshop viable. It would be dry enough that any dust, bugs, etc., rarely had enough time to screw up your paint job. How does BC/CC coatings compare in this respect?
I know, I know, you're supposed to control those invading pest, however, in real life, home workshops, it is nearly impossible to eliminate them, reduce yes, eliminate no. At least, in spite of my best attempts, it was always impossible for me. Yleefox |
The base coat will dry as fast as lacquer used to,therefore dust in the base is kept to a minimum. To me, dust in the clear is no big deal.If you're going to color sand the clear afterwards, all of the dust will disappear.
www.geocities.com/dantechfab |
But then something
That is certainly true of any top coat that is going to be sanded and buffered. I do remember a tiny, black, flying insect, no bigger than a 1/16th of an inch, crash landing in the wet lacquer clear coat on my 65 Corvette. To deep to sand out, so I left it. No one every noticed that bug, that is, except for me. As far as I was concerned, it might just as well have been a buzzard buried in that clear coat, because everytime I walked by the rear of my car, it jumped out at me. Sure wish I would have taken the time to fix it, I could have been more content. Yleefox |
Most of the dust in paint jobs are lint from the painter's clothing or rags being used in the painting area. Dust from air borne particles are too small to see anyways. The color you're painting makes a difference too. All the color sanding in the world won't hide black lint on a white car.
| Need advice on a paint job | tishmomo | Body - Exterior | 36 | 01-15-2008 11:19 AM |
| Quick help with paint question. | 13th_Disciple | Body - Exterior | 16 | 07-29-2005 08:33 AM |
| Newbie Paint Question | alf1096 | Body - Exterior | 8 | 06-13-2005 05:22 AM |
| question on candy paint | CHOPPERzRULeALL | Introduce Yourself | 2 | 08-22-2004 08:46 PM |
| Simple Enough Question - Paint! | Fragzem | Engine | 2 | 10-29-2003 06:53 PM |
