Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Paint Question..
Old 04-14-2013, 01:40 PM
fastnloud's Avatar
fastnloud fastnloud is offline
Originally Posted by 69 widetrack View Post
Several questions for you...How much of your S10 are you painting...inside the doors, under the hood, inside the box? That's all going to make a difference as to how much paint you need. Check with your John Deere paint tech sheets, they will give you ratios for the amount of hardner and reducer you need...always follow these ratios to the letter, especially when it comes to hardner....too little and it won't stand up to elements and won't have gloss retention...too much and it'll take for ever to set up.
Thanks. It's a full size C10 truck, and I'll just be having the outside sprayed, and not inside the bed, will probably do bedliner in there. Do you think a gallon will be enough to do the outside?
