Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Paint question for the experts
Old 05-25-2006, 05:15 PM
48cad 48cad is offline
Chris Ryan
Kevin.... I just shot my 48 Caddy in 2006 chrysler PVE (go Mango), It's very close to Prowler Orange, I actually had a tough time deciding between the two oranges. I used Dupont Chromabase which is a factory pak only color and only available in pints (16 of em @ $38 each). I had the same problem wouldn't cover at all. Shot 5 coats, I thought it was covered, cleared it, next day rolled it out in the sunlight and it still could have used a couple more. I was sick.. Pull it in and scuff it and shot 4 more!! 9 coats of base and 16 more pints!! I used grey sealer under it. I don't know if PPG would have been any better?? I think it is just the color. Alot of the new oranges and red pearls as well as some of the pewter colors are tough to get coverage. Make sure you look at it under sunlight before you complete the job. Artificial lights in the shop don't always show correctly. good luck chris
ID:	12473   Click image for larger version
ID:	12474   Click image for larger version
ID:	12475   Click image for larger version
