Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Paint Questions
Thread: Paint Questions
Old 05-18-2012, 08:31 AM
aarias-31 aarias-31 is offline
Paint Questions
I just sprayed some epoxy primer on my sons truck. It sprayed pretty well but after it dried it seems to be a little rough feeling, you can see the areas where we used body filleralso. Someone said that the filler absorbs the primer and probably needs more coats. We wet sanded it with 400 just a little and now it feels smoothe. I am going to spray 2k on next and wonder if it will do the same thing. Also, after we wet sand the 2k and spray the base coat will we need to sand the base also? What happens if the clear is rough to the touch as well? Any ideas or help? Thanks
