Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Paint Questions
Thread: Paint Questions
Old 02-07-2013, 09:17 AM
33Willys77's Avatar
33Willys77 33Willys77 is offline
You can get away with sanding the single stage and applying just clear or base/clear. BUT, if you sand through the color, you will need to apply primer over that area, otherwise, you risk having the paint lift.
