Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Paint Questions
Thread: Paint Questions
Old 02-08-2013, 12:31 AM
demarques_191 demarques_191 is offline
make sure the runs are hard from the outside and the inside of the run so when u sand the run down... it wont crumble from still being soft in the underlayer.... you can also use a razor blade to shade it but shave only the run itself.. take your time... then when u get low enough you can take some 1200 sandpaper and flatten it out as well as removing any scratches from the razorblade..
