Paint recommendations for Corvette - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-14-2008, 02:26 AM
I've got a 1989 Corvette that I'm gonna get painted at a tech school as I plan on selling it within a year. It is black and has been repainted by the PO. It has some crows feet on the driver door and a million micro white specs on the front nose area. Probably from rocks hitting it. So, I'll have them strip the whole car.
The shop usually uses Dupont. But I'm not interested in spending $1k on paint.
So far I've been recommended SPI which is also priced right. So, it looks like SPI Epoxy on the stripped body. Then probably SPI 2k as I'm sure they probably won't get the Epoxy flat enough to paint on?? Then probably SPI 2k black sealer.
I had been deciding bc/cc or single stage for black. I've been told to go with single stage which is also cheaper than bc/cc. Though SPI isn't doing colors anymore. So, I've been recommended Motostorm single stage Black Ice.
Any tips or recommendations?
Though, it looks good driving around:
Old 11-14-2008, 11:52 PM
BondoKing's Avatar
KING OF BONDO
Last journal entry: My little helper
Get er done..
Old 11-15-2008, 01:47 AM
Originally Posted by BondoKing
Get er done..
Thinking about waiting till it starts warming up as it sits outside. Though, after it does get painted. I'm thinking of putting it in one of those large storage units for at least a month. As that would let the paint finish curing without leaves, bird boop, and rain hitting it, etc.
I figured I'd make a post here to see if anyone has any other tips or recommendations.
Old 11-15-2008, 03:47 PM
adtkart@aol.com
Placing the thing in a storage unit will hurt it as far as curing, as it will get no UV's.
Aaron
Old 11-15-2008, 04:33 PM
Aaron
Oh, ok thanks. So, how long does the car need to sit outside to cure?
Old 11-15-2008, 08:37 PM
35prog's Avatar
Last journal entry: More photos
[QUOTE=Joshwilson] I've been told to go with single stage which is also cheaper than bc/cc. Though SPI isn't doing colors anymore. So, I've been recommended Motostorm single stage Black Ice.
When did SPI quit doing colors??? Bummer. Great luck with the stuff.
Old 11-15-2008, 09:05 PM
[QUOTE=35prog]
A few months ago or so.
The paint did not harden powerrodsmike Body - Exterior 27 03-05-2009 05:34 PM
what color to paint? jum Body - Exterior 14 07-30-2006 12:29 PM
wax and grease remover adrock430 Body - Exterior 14 07-30-2006 12:18 PM
recommendations on black paint please 69 RS-Z Body - Exterior 22 03-01-2005 08:52 PM
