Paint REMOVER
I have a 67 Camaro. the paint (not original) has small bumps under (i think)it. it is flaking of in a few spots like the primer thy used (25 years ago did not adhere to the metal. I want to take it all back to the bare metal to make sure that i get good primer on the metal and a good base for the new base coat clear coat (black) paint to stick to. SO now to my question!!! what is the best way to get all the paint off> I was told paint remover from the hardware store?????/ is there a product that works better on auto paint.........Question number 2 the rust converter stuff (from East Wood) Dose it really work. can i just spray or wipe it on and tada i am done???????ready for paint!!!! my problems are trunk floor and inside doors!!!!!!!!!!! Thank you for any help Larry
chemical stripper is a decent method to remove paint. You don't want to use it on underside of hood, trunk lid etc, wherever it can get underneath bracing. You work a panel at a time. Put masking paper on floor and I prefer to aluminum foil sawhorses or masking paper. Wear respirator, chemical resistant gloves, goggles. Lay it on with brush and follow directions thoroughly. Usually takes 10-15 mins to work before you should start scraping it away. Have fun!
Something that helps when using stripper is to brush it on and lay saran wrap or plastic over it to keep it from evaporating so it works longer..may take more than one application to get to metal..then clean and DA with 80 grit and epoxy prime and you are good to go..
Sam
Keep the strippers away from the seams, and when you are done they have to be neutralized. Just get it wet and active with stripper again and rinse with water. Factory primer usually has to be sanded off.
| DIY infrared paint remover | Jon | Hotrodders' Lounge | 4 | 03-24-2006 08:59 PM |
| wrist pin remover | nix | Garage - Tools | 2 | 01-26-2006 02:02 AM |
| aircraft remover | 6speedwagon | Body - Exterior | 4 | 03-17-2004 07:44 AM |
| paint remover | Busted Knuckles | Body - Exterior | 0 | 03-11-2004 06:00 AM |
| Rust Remover | Kevin45 | Body - Exterior | 2 | 12-07-2003 05:09 PM |
