PAINT & RUST REMOVAL - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Hotrodders' Lounge> Introduce Yourself
Old 07-31-2010, 07:53 PM
I Own Houston Metal Stripping Just Wanted To Answer A Question On A Post About Rust Removal
Old 07-31-2010, 08:03 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Welcome to Hotrodders.
Old 07-31-2010, 08:11 PM
Rust Removal
The Question Was About Removing Rust From A Large Machine With Acid That The Paint Has Been Removed From Leaving A Rusty Surface To Do This Would Cause More Rust The Best Way I Have Found To Remove Surface Rust Is To Use A Product "gem Rust Killer" In The Houston Area It Is Handled By Sherman Williams If You Need More Info On This Call
R.l.Back
1-281-367-4037
Muriatic Acid Rust Removal 11echo General Rodding Tech 23 03-22-2015 10:48 AM
secrets of surface rust removal revealed Randy Ferguson Body - Exterior 178 09-24-2011 10:36 AM
Best abrasive for large-scale rust and paint removal jobs? RLDSL Body - Exterior 18 07-25-2010 05:46 PM
I need more time, rust delay/preventative if not ready for paint? alden Body - Exterior 8 11-10-2009 06:15 AM
electrolisis paint removal stubbys 55 Body - Exterior 3 12-27-2002 05:07 AM
