Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - paint software
Thread: paint software
Old 03-28-2006, 07:17 PM
kenseth17 kenseth17 is offline
I don't know if this will help, but I downloaded a free 3d program called rhino. Think the latest version is 3.0. With a search you may be able to find it to download for free. Its fully functioning, but you only get 25 saves. It can open files made in rhino and also 3ds files made in 3d max which is alot more common to find. If someone happened to do a 3d file of the same kind of car and you could find it to download for free, then you could open the model in rhino, and change the propertys of the parts of the 3d model to a color close to what you thinking of for color, then rotate the 3d model to the angle you are looking for and render it to see what it looks like. You can keep rotating and rendering to see what it looks like at different angles, could probably even put on different rims if you can figure out how to make some in the program of find some already done in 3d.
