Was the rest of the car stripped to metal, or simple primed
over the original paint? If it wasn't stripped, then I'd sand the doors and hatch with 400 paper, not scuff pad, and then prime. No need for Bulldog. The primer will stick fine to well-sanded original paint. This assumes the old paint isn't peeling or flaking anywhere. |
that's what i was thinking... not stripped for the most part but for some reason the prior owner thought write me a ticket red should cover original ppm, gutters and most of the jams flaked off with nothing but my thumb nail down to the original finish, all the red elsewhere held up so it was a whole lotta wet sanding epoxy>2k>bcx3>ccx4
now i'm onto the doors and trunk and a close inspection of the driver side revealed some cracks in the fiberglass near the hinges hence the need for another door and someones got that and the other parts fs locally, i just wasn't sure if i should paint over paint OR go ahead and prime then paint |
old fool - the only metal item left is the hood which i will strip to bare everything else is a plastic/fg composite. On the shell the epoxy went over the red after it was bodyworked and prepped. The way the roof overlaps and the condition of the rockers, I decided not to strip down to bare. A couple of bad accidents by the previous owner and mileage notwithstanding, this one hasn't been our garage queen and probably never will be. The 11 yr old's got his eye on it anyway.
paint sticks better to paint?
what ever metal is on the car sand and epoxy.Give the normal flash time and spray a (what most people call high build)primer over entire car.This will give a nice even surface on it.Block out w/320 or 400 grit and paint.The different color primers will effect the amount of paint it will take to cover it.This will result in shade of the finish product if not carefull.
so far done the way you described except that i've been going slow between coats probably due to my skill level and taking my sweet time. with the light gray primer i had to go 3 coats 2 heavy just to get full coverage, if i had to shoot this color again i'd have the primer tinted - live and learn that's me
| Dupli Color Paint Shop auto paint Lacquer | ChevyTruckGuy | Body - Exterior | 227 | 04-25-2013 09:28 AM |
| Engine paint, high temp paint, Powerder coating??? | zbhover | Body - Exterior | 18 | 06-01-2011 07:16 PM |
| What type of paint sticks to sanded, pre-existing paint? | Rockworthy | Body - Exterior | 19 | 01-25-2011 10:41 PM |
| Sanding back my (less than awesome) first paint effort to paint again | Eric S | Body - Exterior | 5 | 04-11-2008 03:49 PM |
| Paint that sticks to chrome! | willys36@aol.com | Body - Exterior | 2 | 01-07-2005 06:16 AM |
