paint stripper - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-11-2003, 10:22 AM
KNIGHT07731's Avatar
paint stripper
i read what was said below about paint stripper, my question
is once i remove the paint i notice the can said to wash the
surface, how do i handle the wet surface ( i am worried about water causing rust) and what about the stripper
in the cracks i cannot get to, also how long can i leave the
surface in my garage without primer
thanks
Old 08-12-2003, 09:38 PM
If you have access to a pressure washer the that is the only way to make sure you have all the strippwr washed out. Dry the body immediately and spray either a self ecthing primer or epoxy primer otherwise rust will start forming if you leave it setting for any amount of time.
Old 08-13-2003, 06:47 AM
Slickriffs's Avatar
After stripping I've been spritzing with phosphoric acid...A POR 15 product for prepping metal....I'll leave it that way until I'm ready to prime...This product leaves the metal protected with a chromate finish.
Slick
