Paint stripping - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-23-2004, 11:22 PM
Paint stripping
Pulled up numerous posts on this topic and just wanted to ask, won't 80 grit sandpaper leave deep grooves in the metal?
I was planning on using the stripper solvents, but finding they take too long. Should I use the sandpaper approach?
Thanks
Old 09-24-2004, 05:20 AM
BarryK's Avatar
Personally, be it an old vette or the aluminum hood on my Rover, I have never used anything finer than 80 to strip old paint or to clean stripped metal and I have never had 80 grit show up under one coat of epoxy or one coat of primer.
Old 09-24-2004, 05:37 PM
VWFan's Avatar
Farfegnugen
Last journal entry: logo fun!
Same here. I stripped my 68 with 80grit on my DA and any scratches that were there filled with self-etching primer which only coats at about .05mils, so I wouldn't worry about any scratches from the 80grit.
