paint for truck bed - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-02-2007, 08:09 AM
1lowryd's Avatar
paint for truck bed
in wanting to paint my truck bed. i would like to know which i should go for single stage or base coat clearcoat? and if i do single stage will i still have to sand and buff it like with the 2 stage?
Old 03-02-2007, 08:43 AM
Single stage should need no more buffing than Base/clear application. If there is no dirt in the paint and it goes on correctly, BC/CC should need no sanding/buffing.
That said, I'd go with BC/CC and add a flex additive to the clear coat to reduce chipping and scratching inside the bed.
HTH,
Rupe
Old 03-02-2007, 07:39 PM
adtkart@aol.com
Rupe..... Why would you want to use a flex additive? You will gain nothing from that.
Aaron
Old 03-02-2007, 08:07 PM
Flex additives actually slow the dry-through process. Adding flex makes the finish slightly more resistant to chipping and scratching. It isn't a cure-all but if he is going to be walking in the bed of the truck it could keep the scratches from being so noticable.
The paint did not harden powerrodsmike Body - Exterior 27 03-05-2009 06:34 PM
Paint Question #157 rj57 Body - Exterior 5 10-31-2007 03:20 PM
what color to paint? jum Body - Exterior 14 07-30-2006 01:29 PM
wax and grease remover adrock430 Body - Exterior 14 07-30-2006 01:18 PM
