I think it would work better to have mixed a colorative agent with the resin when forming the repair area.
I dont know what you could use, maybe fabric dye like RIT or ???? LA TechThe nail polish may work, or maybe a translucent paint |
Just did some googling and learned that tail lenses are made fromacrylic ploymer, that requires methylene chloride as the adhesive .
Also article said to add color, grind up a piece of another lens and mix it in. Not to sure if vintage cars use the acrylic polymer lenses or when the manufacturers started using them. They used to sell a red lens epoxy, but it is scarce. I think it is not legal as most lenses have reflector area built into the lens for safety at night , say like when the car is parked with the lights off, to keep it fairly visible at night. if you replace the lens with a red epoxy there isnt any way to make it reflectorized as the NTSHA wants to see |
Hey LATECH:
Early in the repair process I tried adding Rit red dye to epoxy and it would not mix in. I never tried this with resin & hardener. I will try dark red nail polish and can always thin it down. BT
I found a way to tint resin red for minor tail light bezel repairs.
1 tsp. resin 4 - 8 drops Rit scarlet liquid dye mix this throughly before adding 2 drops hardener. mix more If you want to make it reflective add some metal flake. BT |
Good info BT. Allways good to know a trick or secret when it comes to stuff like that.
| turn signal | 72steve | Electrical | 1 | 04-16-2009 08:22 PM |
| turn signal | ORHotrod | Electrical | 12 | 10-16-2008 10:14 AM |
| 79 TA: hazard, right turn signal, brake signal out | Gladis | Electrical | 6 | 12-25-2007 10:06 PM |
| Turn Signal | jack76 | Electrical | 2 | 07-17-2007 05:45 AM |
| turn signal help!!please! | LoudMalibu | Electrical | 10 | 06-24-2003 12:04 AM |
