Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Paint wrinkling.
Old 05-26-2009, 11:37 AM
off2wildblue off2wildblue is offline
Paint wrinkling or lifting...help
Can you tell this is my first paint job?
More problems: I repaired the door with back into shape and then I sanded down the clear with 320 and wet 600. Then I let it sit over night and put the wax/grease remover on until cloth was clean. Then I put PPG expoxy sealer down as a first wet coat.
After wet coat the sealer was lifting/wrinkling in about 5 areas the size of baseballs. Of course, not over my repair but over the clear.
So what is my problem and how do I fix it?
I figure after sanding maybe I should have let it sit in the sun or let it rest a few days for the solvents to escape. I just read that in a search anyway.
Also, while doing the search I heard stories of problems with clear coats too.
Lastly, how long do I wait or should I not wait before color sanding and buffing?
My car is still in clear and needs sanding.
Pictures below!
I am very frustrating especially because of the way these doors were damaged.
Please let me know what to do to correct this new problem.
Thanks again,
SAM
Name:	Filler Repair for Damage in Door 005 r.jpg
ID:	38376   Click image for larger version
Name:	Epoxy Problem for Repair for Damage in Door 005 r.jpg
ID:	38377   Click image for larger version
Name:	Epoxy Problem for Repair for Damage in Door 002 r.jpg
Last edited by off2wildblue; 05-26-2009 at 12:05 PM. Reason: Change cause of paint issue
