You're not going to like my answer. But in my opinion the doors were either painted before with cheap paint or lacquer and they will have to be stripped to the bare metal and re-primed to get good lasting results. Another thing, in looking at the pictures it looks like you applied the body filler right over the paint. IMO that too is a no no. Body filler should be applied to bare metal and the existing paint should be feather edged away from it for good lasting results. In the area were the body filler over laps the paint, shrinkage could occur later on down the road.
Another alternative would be to stay away from the epoxy primer/sealer and try using PPG's standard two part primer (I forget the number). Epoxy primer/sealer has a lot stronger solvents and is usually used on bare metal. But guess what? If you are just fixing the car up with a quickie paint job and your'e not worried about longevity, then everything that I just said is crap! Go to your local paint supplier and get some water born primer/sealer. Lightly sand down the wrinkled area just enough to remove the wrinkles and apply the water born primer/sealer to the whole door. Then you can put what ever you want to on it and it should stay down. Paint reps are always a good source of information when ever you have trouble. Don't be afraid to ask. No mater how stupid you may think your question is, they have heard plenty more that are even more stupid then your's Good luck and I hope this helps! Chris Last edited by Chris Kemp; 05-26-2009 at 06:25 PM. |
Well, the paint was Deltron with Deltron 4000 clear. I don't consider it crap but I am not an expert.
The filler was applied on bare metal but was feathered very lightly onto the existing paint but not on much if any clear coat. However, there was absolutely no lifting or wrinkling where the filler was. In fact the repair turned out perfectly. I went to the paint shop today and they thought it was because I sanded the clear too thin or through and then the Epoxy Sealer reacted with the base color and also where the clear was too thin (less than 1 mil). They advised me to use K36 as a primer. Sand that to 600 wet then apply base and clear. I also put on a wet coat of primer which probably should have been laid down dusted for a couple coats and probably should have waited for the clear solvents to evaporate or escape. Can't remember what you call that right now. Then after the dusted coats I could go wetter. Thoughts? SAM |
Well Deltron is good stuff and it shouldn't be doing that. I think that it is the epoxy primer/sealer. Like I said earlier I usually don't put it over paint. I just use it on bare metal. I am not familiar with their K36 but if that is what the paint store recommends then give it a try. I mainly use Sikkens and Glasurit but all of the top quality paint companies have similar products.
Good luck! |
But to sand it off and prime it again is pretty much the best way to handle it. Brian |
Thanks a bunch. I must have sanded too thin. I was so worried about it sticking that I sanded more than I should. That whole "scuff and shoot thing" makes me a little leery. I guess when you say to sand the clear coat to just get rid of the shine you really mean it.
Lastly, after sanding it this time should I wait any period of time for the solvents to dissipate or put it in the sun for a period of time before I prime with K36? SAM |
That never hurts, I don't care what you are spraying, to leave it set a a few hours or more in the sun is going to be a good thing. It simply can't hurt.
And if you spray your next product with a "lighter hand" you are going to have less solvents in the film to soak into the subsrate as well. Brian |
I found this thread googling and had what appears to me the same issue with nasson urethane.
I don't believe the answers here, any, were the reason. I think my problem was I would try to apply another coat 24 hours later of clear. This would lift the clear of day before that was applied 15-60 minutes after base color as manufacturer recommends. The problem came because another entity would turn down thermostat after I left. I think, I needed 24 hours of 70 degree heat so film could fully bond before hot topcoat wouldn't lift the previous coats. Most pro body people wouldn't run into this as the pro is interested in production and wouldn't hit a car two days in a row, and would have better climate control. Last edited by degarb; 03-18-2011 at 09:21 PM. |
I have had the problem of paint wrinkling before when there is a small un sanded area of paint, the solvent seems to attack it if put on too thick. It usually only occurs when doing complicated tape outs and multiple layers.
The key is to let your clear cure before spraying solvents over it. As far as buffing i like to do it within 72 hours. |
| paint information | kimman | Body - Exterior | 8 | 08-10-2012 08:55 PM |
| Paint Question #157 | rj57 | Body - Exterior | 5 | 10-31-2007 02:20 PM |
| what color to paint? | jum | Body - Exterior | 14 | 07-30-2006 12:29 PM |
| wax and grease remover | adrock430 | Body - Exterior | 14 | 07-30-2006 12:18 PM |
