Hotrodders Bulletin Board > Tech Help> Engine
Register now (free) or login to remove ads
Thread Tools Search this Thread share on Facebook
  #1
Old 03-26-2005, 12:51 PM
raidmagic's Avatar
raidmagic raidmagic is offline
Last journal entry: electric fans
painted engine assembly question
Hey guys,
I painted my engine and didn't tape the gasket mounting points for the headers. Should I scrape the paint off where the gaskets will contact or not worry about it? Will the paint cause a sealing problem? The headers are painted as well would that be a concern?
Thanks
  #2
Old 03-26-2005, 02:34 PM
spinn's Avatar
spinn spinn is offline
Tried true
i clean things up with zylene(toululene) .. its grease and paint remover that doesnt leave a residue
Old 03-26-2005, 04:53 PM
MI2600's Avatar
MI2600 MI2600 is offline
Member# 3287
I just use a single-edge razor blade.
Old 03-26-2005, 04:59 PM
docvette's Avatar
docvette docvette is offline
Wiki Edits: 12
Gasket
Doc here,
If you have a dremel, and some fine disks, use that. Outline the gaskets on the head with a laundry pen, then remove the paint just to before the line, the "removed paint won't show this way.Cover or stuff a rag in the ports so you don't get abrasive in there.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 03-26-2005, 05:15 PM
Siggy_Freud's Avatar
Siggy_Freud Siggy_Freud is offline
Id scrape it off. I wouldn't worry about it too much however as the paint will probably bake off within the first few runs of the engine. You'll want to retorque the bolts after the first few runs anyways, which will seal any gaps created by the paint baking off.
Old 03-27-2005, 12:22 PM
raidmagic's Avatar
Thanks guys. I will remove it prior to header install.
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "painted engine assembly question"
ThreadThread StarterForumRepliesLast Post
383 stroker73monteEngine1012-05-2009 09:02 PM
Another Engine Swap Question7skylark6Engine502-06-2004 02:17 PM
nitrous69BiRdEngine211-28-2003 11:33 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
