Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Painted firewall
Old 01-19-2003, 08:25 AM
rdzat rdzat is offline
New Member
Thanks for the info. the runs are in the clear coat not the base, this morning i went out to check and it seems that the runs them selfs are still a little soft how long should i wait before try some sanding a week? The base came out perfectly it was the last coat of clear when i got the run, i'm kinda worried about using a razor with my luck i would probably slice myself, when sanding should i use a small block on the runs is 500 too coarse to start with? i did get three coats of clear on so hopefully i wont sand through. Ron...........
