If you cant get the paint you are after from the same manufacturer just get what ever else you are happy with, there will be no problems at all.
I use what I consider the best and the paint does NOT all come from the same company. |
Yes just sand and go with another brand. You shouldn't use one brands primer and an others hardener. But you don't need to use the same brand all the way through. As far as the paint manufacturer covering any problems trust me no matter what it will be your fault and not covered.
SPI makes a great products you can top coat with..
The PPG or Dupont base will be fine.. You could also look into Pro SPray for a base and SPI Universal Clear Coat to finish it off.. Just some food for thought
I would think that by the time you get all this sorted out, you will be out of the recoat window for the primer on the car. At that point, it becomes an old finish, and you sand it for the requirements of whatever you are putting on top of it.
If you are worried, make a test panel. So far, and I am not going to say this will work in every case, I have applied Dupont Centari single stage, with hardner, over PPG DPLF with DP 402 hardener. |
cool, thanks guys. But I think I lucked out. I contacted BASF and they got me another distributors number, and they bought out my old RM paint dealer.. So hopefully I'll be able to continue on the RM paint trail
If you find a primer that's not compatible with other brands
of paint, let us know so we don't ever use it (LOL) |
| Painters HELP | mafiacustomz | Body - Exterior | 18 | 03-07-2011 10:45 AM |
| Painters | MR.E.Stranger | Hotrodders' Lounge | 2 | 01-06-2011 01:36 AM |
| Help with a dilema. | Harleyvato1963 | Body - Exterior | 27 | 08-10-2008 11:09 PM |
| HK OR ANY OTHER PAINTERS | 80Camino | Body - Exterior | 2 | 10-21-2002 04:47 PM |
| A cam dilema | 1meancuda | Engine | 3 | 03-22-2002 03:38 PM |
