Painting - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-22-2011, 08:47 PM
Painting
im looking for info on painting and alot of it i love cars and that seems to be the only area lacking. Ive painted 1 car with not to good results and primed 2 i will post my steps i used later and i hope alot of you good people will give some info and maybe show some first paint pics.
my paint steps
body work filler sanding ect...
2 coats good high build primer ppg 1.8 2.0 tip gravity guy
guide coat rattle can black
fix any bad spots filler glaze ect...
2 coats primer sometimes with sealer 1.8 2.0 tip gravity guy
wetsand
base coat 2-4 coats 1.4 tip gravity guy 10-15 min flash
clear coat 2-4 coats 1.4 tip gravity guy 10-15 min flash
wetsand buff and polish
when i did clear befor i used a 1.8 tip and i looked around and everyone in body shops and custom painting used 1.4 1.3 tip gravity guy.
so where i can i improve is their any info you need to know to help with my steps to make me a better painter.
Old 10-31-2011, 09:30 PM
What was your problem , Orange peel, runs / sags, dry spray , , I like to use a hvlp gun myself and I use a 1.4 for everything I have awsome results, my suggestions is relax get comfortable with the gun spray a couple of test panels, pratice makes perfect , it will come to you, if your getting orange peel open up the flow of paint, same with dry spray , if your problem is runs and sags spray a medium tack coat and wait 15mins to 30 mins before 2nd coat . And remember to keep your gun at least 7" away
Old 10-31-2011, 10:44 PM
i was getting the crows foot but that was becouse it was cold at night when i did it and the other thing is i sprayed the clear with a 2.0 tip and it went on like gel
Painting inhalation2 Body - Exterior 1 08-19-2010 05:16 PM
Painting shadowismydogsname Body - Exterior 2 01-14-2008 10:31 AM
New to painting DesertIvy Body - Exterior 5 03-13-2005 10:50 AM
Painting kf6myv Body - Exterior 7 09-17-2003 01:31 PM
1st painting nova33 Body - Exterior 19 06-16-2003 10:05 AM
