Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Painting at 60 degrees
Old 10-22-2009, 07:53 PM
FRANKBULLITT's Avatar
FRANKBULLITT FRANKBULLITT is offline
Make sure the metal is at least at the high temp.As soon as the overspray is gone turn the heat back up for the coat to flash off then respray and repeat the process, thats what we used to do in michigan when it was cold.But dont spray below 60 unless you want problems and use the appropriate reducer for the temp.
