painting - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-06-2006, 11:08 AM
painting
how do you paint galvanized posts prep etc.
Old 10-06-2006, 11:33 AM
astroracer's Avatar
As with anything else it needs to be clean of course and wiping it down with a good wax and grease remover is important. If it is chaulky you should clean it up with a maroon scotch-brite pad and then degrease right before paint. ZincChromate primers are used on galvanized panels but most any 2 part epoxy should be equally up to the task. Ask your jobber at your paint store.
Mark
Old 10-06-2006, 11:42 PM
My Dad always wiped the piece with good old vinegar. It works.
Old 10-07-2006, 12:19 AM
Be carefull with anything galvanized, welding or grinding, you could get in trouble in a hurry.
Rob
There are questions to be answered, and answers to be questioned"
Chassis, Body Jig, Trunk Pan Pics.
http://webpages.charter.net/2manitowoc
Paint booth, Ventilation, etc.
http://www.2manitowoc.com/paintroom.html
Old 10-07-2006, 12:21 AM
Brian_B's Avatar
Lost in the 50s!
Last journal entry: time to start body work
The steel fab shop I used to work in soaked galvanized parts in vinegar before painting, just like bartamos said.
It "etched" the surface and the paint would stick.
Painting in your Garage Centerline Body - Exterior 22 08-31-2007 11:23 AM
Sandblaster compressor used for painting? Siggy_Freud Body - Exterior 8 10-04-2006 11:03 PM
Prepping and painting new/dipped parts? tcruise Body - Exterior 5 10-17-2005 01:52 AM
Painting a computer case? Grump Body - Exterior 9 10-08-2003 09:26 PM
chassis painting 38 special Body - Exterior 3 03-10-2003 01:22 PM
