Painting airplanes - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-16-2012, 06:44 AM
Painting airplanes
I'm interested in using Nason products over aluminum to paint my airplane. It's almost finished after taking 11 years to build
Old 05-16-2012, 08:32 AM
boatbob2
Airplane painting....
Ive painted well over 150 airplanes,after 11 years building/restoring an airplane,why not use a better paint? ALWAYS have plane stripped to bare metal,REMOVE corrosion with nylon wheel,(if you keep planes surface WET,corrosion will be removed MUCH FASTER,without nylon wheel,leaving black streaks,,(trade secret)(wear bathing suit) REMOVE ,Flaps,Rudders,elevators and Aerilons,remove all inspection plates,i ALWAYS used EPOXY Zinc-Chromate as a primer,spray primer (2 coats)let the plane and parts set for a full day,using a 3M GREY pad,i scuff all parts,then i paint with either ALUMI-GRIP,OR AWL GRIP,or IMRON,(IF using IMRON,keep at LEAST a quart of paint for touch-up.REPLACE ALL screws,nuts and bolts with S/S,REMEMBER,you must use 12 inch numbers after painting...
CAN Aircraft or Airplanes be Hot Rods? MXrider13 Hotrodders' Lounge 17 07-15-2011 11:11 AM
For those who like airplanes Irelands child Off-Topic 8 03-23-2011 02:49 PM
Painting inhalation2 Body - Exterior 1 08-19-2010 05:16 PM
Looking for someone who is painting soon... ge0rge Body - Exterior 7 02-04-2007 05:31 AM
painting help volkswagentuned Body - Exterior 1 10-19-2005 04:15 PM
