Painting Aluminum Intake - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-17-2006, 12:17 PM
123pugsy's Avatar
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
I'd like to hear some opinions on painting a cast aluminum intake manifold.Is there a paint from a spray bomb that will stick good ,withstand heat and withstand engine cleaners/degreasers?
I also have to finsh the TPI tubes,fuel rails,....
Thanks,Pugsy
Old 10-17-2006, 12:42 PM
astroracer's Avatar
Painting aluminum (or anything for that matter) is 99% preparation and 1% application. Making sure you have a clean, oil and grease free surface will go a long way to the longevity of any paint job. Most of your spray bomb engine paints will live just fine as you have mentioned if you get the surface prepped correctly.
Mark
Old 10-17-2006, 02:58 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
You can purchase aluminum prep products from auto paint supply houses. Its an orange etching compound that you spray on, leave it a litle bit, then hose off. It helps paint adhere. I use in on aluminum boat hulls since they're so smooth its tough to get anything to stick.
The rough casting of the aluminum will hold paint really well, unless you're really scrubbing on it frequently. I've had really good luck just cleaning a new intake with soap and water, then using engine paint. Its designed to hold up to high heat and chemicals.
Old 10-17-2006, 07:26 PM
rj57's Avatar
If you have an engine rebuild shop near you call and ask how much they'd charge to dip the intake in their solvent tank for a while? You do NOT want the intake hot tanked as that runs the risk of warping the intake.
But a solvent bath would be fine for it.
Even after doing this when I got it back I'd still wash it with soap and water to remove any possible residue left behind.
The intake on the 350 in my 150 Handyman 2-door Wagon has been painted the entire 18 years I've owned the Wagon. My buddy painted it when he owned the Wagon.
Old 10-17-2006, 07:30 PM
S10Fan's Avatar
Garage Filler
Last journal entry: I need more time!
I painted the engine in my truck 3 months ago (including an aluminum intake) with single stage paint. The engine was out of the truck and cleaned. No paint issues what so ever.
Old 10-17-2006, 08:01 PM
Tominator's Avatar
Even Wal-Mart sells an aluminum primer in a spray can. After a very through cleaning I used it on a Performer manifold several years ago and painted it with engine paint. Still looks good!
Old 10-18-2006, 10:13 AM
hotrodf1's Avatar
Chasing dreams with a ball bat
Powder coat it!
Get a used oven , put it in your garage (can't bake powder in the house - toxic!)
Buy a cheap powder coat kit from harbor freight tools.
Powder from Eastwood auto or wherever.
Works great, faster than paint and dry, more resistant to heat and chemicals, more durable.
I powder coat all my little parts instead of painting. It's so simple.
Old 10-18-2006, 12:03 PM
S10Fan's Avatar
Garage Filler
Originally Posted by hotrodf1
Powder coat it!
What he said!
Old 10-18-2006, 12:19 PM
123pugsy's Avatar
Wiki Edits: 29
Powder coat sounds good.Does it come in a high gloss? I'd like to get my TPI looking something like this. Not sure of colour but the gloss looks great.
[IMG][/IMG]
Old 10-18-2006, 06:36 PM
rj57's Avatar
If not cleaned GOOD powder coat can flake off.
Old 11-16-2006, 06:48 PM
123pugsy's Avatar
Wiki Edits: 29
Thanks for the responses guys.I got it powder coated hammertone grey and it came out quite nice.
[IMG][/IMG]
Old 11-16-2006, 06:57 PM
hotrodf1's Avatar
Very nice!
Looks good. You wont' regret it . . .
Painting in your Garage Centerline Body - Exterior 22 08-31-2007 11:23 AM
Lifting a motor by the intake junkyardjeff General Rodding Tech 51 09-20-2006 09:37 AM
Painting a Powdercoated intake? 79 Malibu327 Engine 1 09-29-2004 07:37 AM
62 corvette aluminum intake manifold custom Engine 1 10-22-2003 09:49 PM
Painting an aluminum block babyface Engine 4 05-08-2003 03:13 PM
