paint stuff!
try to prime very lightly,i painted my 283 chevy motor with the winkle machine finish they put on machines at factorys or just use the run of the mill engine block paint but it chips if you hit it with a tool,you also can use a mag wheel spray with a hard clear that is also out (petboys ect.) give it a try if your trying to save money, if money is no object then just thermo-coat it,thats cool too................bourne51@netzero.com
One of the issues with painting aluminum is how fast it corrodes. For best results and adhesion be sure to get a primer (self etching if possible) on the aluminum within an hour of sanding. Don't let it sit after sanding. The moisture in the air will be enough to start the oxidation process.
There are literally thousands of different aluminum alloys. Some will corrode faster than others. Without knowing what your valve covers are made of, better safe than sorry. |
| Painting bare aluminum clear | esahlin | Body - Exterior | 4 | 01-25-2006 04:46 PM |
| Short valve covers too tall... | ChevApache59 | Engine | 11 | 12-06-2005 07:05 PM |
| Painting an aluminum block | Arrowhead | Body - Exterior | 4 | 10-28-2005 07:13 PM |
| Supplier of nice center bolt sbc valve covers? | McDeuce | Engine | 3 | 11-24-2003 06:21 PM |
| Cam Help | black66 | Engine | 3 | 05-12-2003 06:15 PM |
