Painting another hood, heres my plan. Had problems before - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 04-27-2009, 11:18 AM
Moderators note
Image deleted for profanity
Vince
Last edited by 302 Z28; 05-02-2009 at 07:12 AM. Reason: Violation of guidelines. Please see: general board guidelines.
  #17 (permalink)
Old 04-27-2009, 01:54 PM
read this ---Are the little bubles coming up after the clear has been applied or while you're appling the clear? What is the ambient temperature? What is the humidity level? What clear are you using? It sounds like it could be fisheyes or solvent pop. If it's happeng while you're applying the clear, it's probably fisheyes. This is a contamination on the vehicle problem, and can be corrected by washing with soap & water followed by a solvent cleaner (wax & grease remover). you will have to sand past the fisheyes, where they are removed completly - clean correctly, reapply color and clear. If the problem is solvent pop, this is a problem where the solvents were'nt allowed to flash (evaporate) before subsquent coats were applied. This traps solvents in the lower coats, when they finally evaporate they bust through the very top surface of clear which has started getting hard allready. This can be caused by; too high a temperature for your clear, not enough flash time between coats, too low air pressure, coats being too wet, and high humidity makes it worse. Clears have two types of solvents; flash & transfer. The transfer solvents evaporate on the way to the car, and the tail solvents evaporate after the clear has been applied (this leaves the film wet enough to allow all of the clear to be applied without getting dry spots. If your gun is too close to your work, or air pressure is too low it will trap the transfer solvents which causes the clear to skin over rather quickly. This traps the tail solvents, and when they do evaporate it pops holes in the finish. The only way to repair solvent pop is to sand past the affected area, reapply color and clear. The white specks sound like the wetsand residue in the fisheyes or solvent pop. When you wetsand clear the residue is white, this gets into the low areas (pinholes from solvent pop, or craters from fisheyes) and looks like little white specks. You will have to sand past those, or it will never go away. No matter how many time you clear it won't go away until they are removed completly.
  #18 (permalink)
Old 04-27-2009, 04:26 PM
Moderators note
Vince
Last edited by 302 Z28; 05-02-2009 at 09:27 AM. Reason: Profanity. Please see: general board guidelines.
  #19 (permalink)
Old 04-28-2009, 03:07 PM
Moderators note
Vince
Last edited by 302 Z28; 05-02-2009 at 07:13 AM. Reason: Violation of guidelines. Please see: general board guidelines.
  #20 (permalink)
Old 04-28-2009, 03:22 PM
you haven't listened to any thing these guys have tried to tell you so far-- its not worth the effort-- I'm done with this thread
  #21 (permalink)
Old 04-28-2009, 04:52 PM
Moderators note
Vince
  #22 (permalink)
Old 05-01-2009, 09:50 PM
Wow, I guess its time for this thread to be dumped
Some people, I just don't know
  #23 (permalink)
Old 05-02-2009, 05:36 AM
shine's Avatar
SPI Thug
Last journal entry: some progress
you just displayed your intelligence . glad your not coming back moron .
  #24 (permalink)
Old 05-02-2009, 05:39 AM
He sounds mad about something.Might try thorzine?
  #25 (permalink)
Old 05-02-2009, 05:43 AM
shine's Avatar
SPI Thug
he's just mad cause he cant paint a simple hood and too stupid to listen . his little post edit shows his age and intelligence .
  #26 (permalink)
Old 05-02-2009, 06:34 AM
i wasent trying to piss him off-- -he ask a question and i thought i might try to help-
what bothered me was --he posted he had painted a lot and then ask how to adjust his gun-??wats yup with that?/--
i did read all his post --oh well -- im sure soon the mods will delete this thread--
sorry he felt that way--
  #27 (permalink)
Old 05-02-2009, 07:46 AM
302 Z28's Avatar
Moderators note: If that profane text image is posted again further administrative action will be taken.
This thread will be left open for the time being, but it is being watched.
Vince
  #28 (permalink)
Old 05-02-2009, 08:01 AM
thanks 302 now if we could get you to buy a ford you might be an allright guy--
  #29 (permalink)
Old 05-02-2009, 08:21 AM
302 Z28's Avatar
That's asking a lot
Vince
Tips on painting truck roof and hood? LanceM Body - Exterior 8 07-27-2006 01:42 AM
Hoods not shuting all the way 74_Chevrolet Body - Exterior 5 09-01-2005 07:10 PM
Best ways to straighten a twisted repro door? Ripped Body - Exterior 13 07-04-2005 07:29 AM
Splitting a hood Dreadlord Body - Exterior 36 12-29-2004 07:16 PM
Questions about painting a hood... Fatal_charm Body - Exterior 1 09-10-2004 10:23 PM
