Painting another hood, heres my plan. Had problems before - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-25-2009, 04:26 PM
nevermind
Moderators note
Image deleted for profanity
Vince
Last edited by 302 Z28; 05-02-2009 at 09:25 AM. Reason: Profanity. Please see: general board guidelines.
Old 04-25-2009, 11:18 PM
Please don't use that rustoleum wax and tar remover as a final wipe cleaner. Just use 50/50 alcohol and water.
Old 04-25-2009, 11:33 PM
Moderators note
Vince
Old 04-26-2009, 12:10 AM
Moderators note
Vince
Last edited by 302 Z28; 05-02-2009 at 09:26 AM. Reason: Profanity. Please see: general board guidelines.
Old 04-26-2009, 07:28 AM
This just cracks me up.
Chop
Old 04-26-2009, 07:40 AM
Moderators note
Vince
Old 04-26-2009, 07:51 AM
Moderators note
Vince
Last edited by 302 Z28; 05-02-2009 at 07:12 AM. Reason: Violation of guidelines. Please see: general board guidelines.
Old 04-26-2009, 08:37 AM
shine's Avatar
SPI Thug
Last journal entry: some progress
it's obvious you don't know what your doing so it might help to listen instead of arguing. this is why fewer and fewer are answering questions . don't expect quality results unless you use quality products and rustoleum is not one of them .
Old 04-26-2009, 09:22 AM
Moderators note
Vince
Old 04-26-2009, 09:59 AM
shine's Avatar
SPI Thug
water and alcohol has been used as a final wipe forever . not harsh , just enough to get rid of body oils and prints. the more solvents you introduce into the job the more likely you'll have problems. i see people recommending cleaning with lacquer thinner which is the absolute worst thing to use. you want a successful job use quality products that are compatible .
Old 04-26-2009, 11:03 AM
Moderators note
Vince
Old 04-26-2009, 12:20 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Here is the thing..one can use some home grown solutions to "get ya by" when nothing else is available...like maybe you are out of the good stuff and you need to get the job done..I use the waterborne W&G remover from SPI to do the final wipe down and make sure it is dry and evaporated before shooting paint..
Those guys who have done a lot of cars have been burnt and speaking from experience some of the home grown solutions have burnt me as well as others..That is why we have gotten set in our ways so to speak and use the products and methods that work well..All it takes is one mad customer and a do over out of your pocket to make you a believer..
See in the old days when I learned if you screwed up a job you had to fix it out of your own pocket as it was part of being an apprentice..todays world does not do much for responsibility..
Sam
Old 04-27-2009, 01:16 AM
Hummmm, sorry if I offended you. Anyway, A Wax and Grease remover that is made to be used as a pre-prep (before sanding) cleaner is too harsh to be used as a final cleaner. the 50/50 mix of alcohol and water works great as a final cleaner, if its too "Home Brew" for you then there are plenty of final cleaners that you can buy from your automotive paint jobber. That Rustoleum cleaner that you had a link to was NOT a final cleaner.
I don't get it, why did you delete your postings?
Old 04-27-2009, 06:28 AM
Moderators note
Vince
Old 04-27-2009, 10:14 AM
you had solvent pop because you sealed --glazed--or waxed to soon --
alcie and water -- has worked for me for over 35 years--
Tips on painting truck roof and hood? LanceM Body - Exterior 8 07-27-2006 01:42 AM
Hoods not shuting all the way 74_Chevrolet Body - Exterior 5 09-01-2005 07:10 PM
Best ways to straighten a twisted repro door? Ripped Body - Exterior 13 07-04-2005 07:29 AM
Splitting a hood Dreadlord Body - Exterior 36 12-29-2004 07:16 PM
Questions about painting a hood... Fatal_charm Body - Exterior 1 09-10-2004 10:23 PM
