painting the backside of fenders, hoods, tail-gate, etc. - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-26-2007, 09:26 AM
Hey guys...working on a 95 S-10. I was just wondering...I'm putting 2 new fenders on the truck...how much prep should I put into the insides of the fenders...like the part that's visible when the hood is popped? Also, should I clear these? Or leave them with no clear and looking semi-dull? Not doing a SHOW vehicle by any means...it's a 4x4. My ex wrecked it, had to put a front clip on it...2 new fenders, and I decided to order a cowl hood too...it's got a smooth inner liner, though, so I figure I'll clear the bottom of it too. And also, the tailgate.
I was thinking I'm probably just going to use a brown scuff pad dull the black primer out a lil bit...prime the front and back of each panel when I do the rest of the priming, then paint and clear all the back-sides. throw everything back together and paint the truck as a whole.
Sound like a plan?
Old 07-26-2007, 10:29 AM
Originally Posted by Custom95Z
H
Sound like a plan?
That's a good plan. All I would add is that you should mask off the outside of the fenders when you paint the inside. This will prevent overspray from causing a problem with the exterior paint, since the basecoat won't adhere that well to the clearcoat. It saves sanding and possible problems later.
94 chevy stepside tail gate 53belair Body - Exterior 1 05-16-2007 06:40 PM
El Camino Tail Gate gsheets Body - Exterior 3 09-13-2005 12:22 PM
Painting of inner fenders etc? Gearhead forever Body - Exterior 8 02-08-2005 10:44 AM
Silverado Tail Gate "Chevrolet" Panel mav79 Body - Exterior 0 07-31-2003 08:00 PM
Tail Gate Mirror Image Body - Exterior 0 03-23-2003 06:12 PM
