If you are spraying a solid color then you should have no problem painting it in sections one thing you have to make sure is that you allow enough flash time I have been in a hurry before and clear to soon and it will turn the base a yellow color and white is the worse color to do that
First off, what color undercoat are you using? Any chance you just didn't get complete coverage? The coverage on OMNI is horrible from my experience so it would be easy for it to be a little transparent exposing more of your primer color.
I've seen something like this before years ago with the old sikkens autobase. It was actually what was explained to me as a "float" that would cause the color to be different depending on how heavy or light it was sprayed. Light and pastel shades of color were the only time you would see it. I haven't seen it in years though. It wasn't a big deal then because we blended almost everything and when I did an overall I painted it all at once. I've seen clear yellow a bright white before but only because one batch or a different brand was used and the 2nd batch/brand was much yellower. I've never seen clear cause that much color change from the same can only in different areas. I hate to say it but it looks like it's time to do some blending! |
Yes you were right i didn't put enough coats on the rear end "damn omni". After you posted that i went out started looking at the car a noticed that it only look like the quarter panels, then i knew it was my primer showing threw here is a nice picture of how i primed it.
![]() I then painted the gas cap door again just to make sure and what do you know it looks great. ![]() ![]() ![]() Well thanks guys i appreciate your help here is some more picture of what the quarter use to look like. ![]()
Here is an article that covers just about every thing you need to know to paint a car in pieces or sections.
Click here for the "Baiscs of Basics" to painting a car in sections. Other than of course as mentioned different undercoat colors and not enough paint applied, or more clear was applied. "More" doesn't always mean more coats, if the gun speed is slowed down, if you use more overlap, there are many reasons to cause more film build of clear. And yes the amount of clear can change turn the white yellower even if it is the same brand. Some clears are very yellow, the more you add the more yellow it becomes. Brian |
| what is the fastest (factory) car you have ever driven? | badknuckles | Hotrodders' Lounge | 320 | 12-09-2011 01:32 AM |
| Paint and body work warranties ? | juggernaut | Body - Exterior | 12 | 01-29-2010 06:14 PM |
| painting car today need advice please | elcaminodragster | Body - Exterior | 18 | 06-11-2009 04:54 PM |
| Roll Bar Install Advice | Mustangsaly | General Rodding Tech | 12 | 12-02-2007 08:33 AM |
| It's all in the details... | Nightfire | Hotrodders' Lounge | 18 | 09-16-2006 09:53 PM |
