painting car today need advice please - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 06-10-2009, 04:14 PM
elcaminodragster's Avatar
70 El Camino aka FRANKENSTEIN
Originally Posted by Wraith
Is that your frist time doing body work? Not to be and *** but you should of did alot more blocking on the body work on that car.
You are not being an ***. Yes this is my first time doing body work. I have no real knowledge in body work nor paint. I didn't have the proper tools to do body work so I did my best. I knew it would not come out perfect, but I'm happy with my first time doing it. Plus I'm no show car. I am slowly building this to be a weekend worrier.
The hood stripes are not a silver. I could not get the right lighting for a good pic to show the true color. The color is cloud gray.
  #17 (permalink)
Old 06-10-2009, 08:09 PM
Born to lose,living to win
No worries man you learn as you go,you should do a search on sanding filler and shaping on this forum lots of good info here.
  #18 (permalink)
Old 06-11-2009, 12:52 PM
And what brand is this cloud grey ??
I assume it is a satin color as opposed to using a satin clear over it ????
By the way......... Very good tape off Job on the stripe
52F1
  #19 (permalink)
Old 06-11-2009, 04:54 PM
52F1
Industrial Imron from Dupont a quart kit was $70. Its not the best paint i know but i took my time on the prep work (which is everything with paint) and it came out flawless. 2 coats and its perfect sharp lines beautiful coverage. It stuck really well. Only time will tell how it will hold up.
I found out after I sprayed it that my friends grandpa uses it to paint his farm equipment and it holds up fairly well for the abuse its put through. Only he sprays 4 or 5 coats.
Roll Bar Install Advice Mustangsaly General Rodding Tech 12 12-02-2007 08:33 AM
Crashed car, opinions/ advice needed! BMM Hotrodders' Lounge 5 11-25-2006 01:53 PM
Painting roof tips needed..... Bluepen Body - Exterior 7 09-10-2005 09:26 PM
how would you make it legal?? spooki General Rodding Tech 8 08-31-2003 09:16 AM
Story time. Halloweenking Hotrodders' Lounge 17 05-19-2003 10:16 PM
