painting dash in or out of car - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-12-2011, 01:37 PM
Last journal entry: rumble seat work
I am in the process of getting all the lights and other electrics finished and will be installing wire harness. is it better to wire the dash instruments in the car and then paint the dash or take out dash and paint then wire? sc
Old 12-12-2011, 04:55 PM
swvalcon's Avatar
Last journal entry: rust on lt body shell
You can do a much better job on the paint if you do it out of the car and before you install anything into it.
Old 12-14-2011, 07:44 AM
dash painting
ok, now i plan on painting my car a candy apple red, this is not a show car, what is the best type of paint to use that will be fairly simple to use and will last in the weather. the car is garaged.
Old 12-14-2011, 09:11 AM
HOK used to make a candy-style paint the was supposed to be easier than a true candy.
Ive also seen some guys use a single stage paint, and dilute it with a clear, each coat diluting it 25% more than the last, following with a coat of straight clear.
Example:
Coat 1 100% single stage
Coat 2 75% SS and 25% compatible clear
Coat 3 50/50%
Coat 4 25/75%
Coat 5 100% CC
Note:
I've never done this nor do I have any idea how durable it is.
Seems like a LOT of film build, but a lot of custom paint jobs can have lots of layers.
Candy is NOT easy to paint; if you dont have a lot of experience, you might be better off with finding a Modern OEM-style finish that meets your needs
Painting my dash and interior panels....... labreejr Interior 1 07-16-2009 10:24 PM
Dash painting Hotrod74 Interior 12 01-08-2009 12:05 AM
Painting dash vents 68NovaSS Body - Exterior 1 06-27-2008 05:47 AM
Painting the dash of a 56 ford Jillopy33 Body - Exterior 2 11-07-2007 10:27 AM
Interior dash painting on a 62 caddy rbfpezcore Interior 3 06-07-2005 09:23 AM
