Painting door jambs on 35 - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-12-2009, 07:02 PM
Last journal entry: Con't
Got car block sanded finally (I hope) and plan to cover everything with epoxy primer next week. I want to do door jambs the same time. Rest of car I stripped to bare metal but I plan on painting over original paint on jambs. I have gone over them with a wire brush on a drill and scuffed best I can with 80 grit. I plan to go over them with a scrub brush and grease and wax remover and then coat with Bulldog before priming. My question is : there is some surface rust in spots on the jambs - some I cant get to very good. Should I try to get navel jelly on it (even if I may not be able to rinse well) or will the epoxy primer seal it good enough. Please let me know if you see any other flaws in my "plan". Thank you
Old 12-12-2009, 08:50 PM
put some rust converter on it for sure , spray can at lowe's .
that 80 grip going to make it look like you brushed painted it .
go to some 320 at some point and primer and hit again with the 320 and a scrub pad ,fine type .
Old 12-12-2009, 09:06 PM
blue
Blue
Got Access To Sandblaster?naval Jelly Will Work,but Youll Still Have To Rub It.youve Done A Lot Of Work So Far(right?)go A Little Farther.and Do Go Over It With A Finer Paper Before Spraying .good Luck
Painting, getting cold... don't feel like blowing up dest1971 Body - Exterior 8 11-01-2009 04:53 AM
35 Ford Pickup cab and frame width?? Super Chevy General Rodding Tech 6 01-19-2009 12:36 AM
Painting piece by piece? vintage guy Body - Exterior 9 10-24-2008 08:13 AM
35 Ford Coupe front clip on 35 Ford truck 35hotrodtodd General Rodding Tech 8 12-27-2007 02:00 PM
