painting door jambs - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-04-2006, 01:01 PM
painting door jambs
Im a begginner in the hot rod game and Im just researching do-it-yourself auto painting, I have an 87 chevy caprice, not much for a hot rod but its got the 305 and i got it for practically nothing from my uncle. Im wondering wats the best way to paint door jambs and would you need to take off the doors to paint the part of the jambs with the hindges and other hardware or could you just go over all that stuff. Also how many coats of primer would you use and is paint stripper acceptible for taking off old paint coats. Im just a kid tryn to learn about this stuff so someday i can get it all right. Thanks for the help
-Matt
Old 01-04-2006, 04:08 PM
Welcome Matt, first you have to decide how deep are you going to go on this car. Taking the doors off will give you a better job but not that much better. Are you changing colors? If you are going from a red to a white, then any missed red will look like crap. But if you are going to a similar color you don't need to remove the doors at all.
Priming, not needed at all in the jambs usually if the paint is decent and you are just repainting. And you CERTAINLY don't need to strip that paint on the jambs.
What color is the car and what color do you plan?
Old 01-04-2006, 04:47 PM
302 Z28's Avatar
All of what Martinsr siad, in addition make sure you clean those door jambs real good. Remove all dirt and traces of silicone (Armor All) or other oils.
Vince
Old 01-04-2006, 08:29 PM
X711
Welcome to the fourm Matt.
A couple of things to consider.
The easy way to access the hinge behind the door is to unbolt the fenders
and slide them forward or swing them out. I would not attempt to remove the door as it is a bit*# to put back on. No point in making extra work for your self !
Before you paint clean all accessible areas to make sure they are free from
dirt and oil.
Priming in the Jambs is typically not needed unless you have rust that needs
to be removed first. If paint is flaking or bad, you can sand it flat. If you
sand so the metal shows just dust on some primer then paint.
Dont forget to mask all areas around the jambs before you spray.
Best regards X
Old 01-05-2006, 10:52 AM
thanks so much for all your help. The car is silver i plan to paint it a metallic light blue. for the rest of the body do you think its ok to use liquid stripper to take off all the old layers, or should i just sand it down to the old primer? the paint is in good condition , how much do i need to take down if any?
Painting in your Garage Centerline Body - Exterior 22 08-31-2007 11:23 AM
Sandblaster compressor used for painting? Siggy_Freud Body - Exterior 8 10-04-2006 11:03 PM
Prepping and painting new/dipped parts? tcruise Body - Exterior 5 10-17-2005 01:52 AM
Painting a computer case? Grump Body - Exterior 9 10-08-2003 09:26 PM
chassis painting 38 special Body - Exterior 3 03-10-2003 01:22 PM
