painting door panels in a 73 nova?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-06-2006, 01:18 AM
fireforsin's Avatar
Novaaaa
i have a 73 nova and the interior is this plastic type door panels and rear panels. i was curious if anyone could give me some advice on painting them because i have tried and all they do is flake off, even after using primer. is there some sort of dye?
thanks,
mike
Old 05-06-2006, 01:24 AM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
Were you using the special plastic paint?
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Old 05-06-2006, 01:32 AM
fireforsin's Avatar
Novaaaa
no...just some spray paint, but did put some primer on there.
Old 05-06-2006, 01:56 AM
home brew's Avatar
You will have to purchase a special paint designed to stick to plastic. It is available at auto stores.
Old 05-06-2006, 03:49 AM
Kevin45's Avatar
Just one of the guys
Last journal entry: Vise jaws
Did you use an "adhesion promoter" before painting? Usually on plastic parts you have to scuff, clean, use adhesion promoter, flex agent in paint, let dry, assemble. The flex agent eventually dissolves out of the paint but lets it remain flexible enough to allow for assembly. The adhesion promoter allows the pores of the plastic to open up somewhat (something along that line) to allow the paint to stick. You can get this in a rattle can at your local jobber. Or you might consider a plastic dye / paint. Usually your local jobber carries this. Just about any plastic part that you buy for a new vehicle has to be dyed to match the interior. Most parts come in universal grey or black and then you dye them to the color of your choice.
When I put my new grille in my truck, it came in black plastic. I had it painted using the adhesion promoter and paint to match the truck and have not had the first problem with it in two years.
Kevin
72 nova door panels to 73 doors... fireforsin Interior 2 02-18-2008 04:45 AM
BMW M3 vs 73 nova, opinion needed. Sagacious Engine 12 10-04-2004 09:33 PM
73 to 70 nova brake swap Gassman Suspension - Brakes - Steering 5 04-13-2004 02:28 AM
Big block for my 73 Nova Hatchback? 73 Nova Guy Hotrodders' Lounge 7 02-26-2003 10:40 AM
73 nova nova33 Engine 3 10-11-2002 05:01 AM
