Painting with Dupont Hot Hues Paint - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-02-2011, 09:08 AM
Does anyone know if this is a type of paint that can be repaired if it is scratched or if repairs are necessary? I've heard that some paints cannot be matched and the whole care must be repainted. Help!!
Old 03-02-2011, 02:16 PM
Underground's Avatar
Last journal entry: 54
depends, is it candy? If it is, good luck. It takes a VERY experienced painter(experienced with fixing candy!) to do the job. Which Hot Hues color is it? Do you know if the color was "tweeked" in the mixing room? Alot of times painters will add more pearl, ect.. in it to get the custom shade the customer wants. If it is a standard HH mix, then there should be no reason an EXPERIENCED painter couldn't repair it. Alot of times it is EASIER (and only SLIGHTLY more expensive)to repaint the whole car instead of repairing. You have to figure the time invested making sure everything is just right to make an unnoticable repair.
Old 03-02-2011, 04:05 PM
painted jester's Avatar
TAKE A KID TO A CAR SHOW
Last journal entry: Wifes 79 comeing together!
are you deciding whether to paint with hot hues, or are you in need of a repair on an existing paint job?
Old 03-04-2011, 06:33 PM
Rag top bird's Avatar
Hot rods are still the king
Using the top brands of paint I have not had one that I couldnt match close enough to blend some or harder then others and most of the time you have to blend into the next panel
Dupont Paint Job n0ferz Body - Exterior 7 08-29-2009 03:36 AM
Dupont Hot Hues Supplier in Orlando? mverta Body - Exterior 0 05-28-2009 06:37 AM
Dupont Hot Hues MIKE FROM SM Body - Exterior 6 02-17-2007 10:11 AM
dupont paint Checy_Guy Body - Exterior 20 04-17-2006 12:46 AM
Paint color question (hot hues)? fatnlow Body - Exterior 3 02-28-2006 12:40 PM
