Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Painting an engine!
Old 05-10-2004, 06:11 PM
willys36@aol.com's Avatar
willys36@aol.com willys36@aol.com is offline
Wiki Edits: 21
Been discussed several times on the board. Like Tom said, cleanliness is the key, no matter what you use. I normally powder coat my engines but those that I paint, I use etching primer, hi-build primer, & BC/CC urethane, just like a body. Holds up to heat great, grease, & gas & looks like a million.
