Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Painting an Engine
Old 04-07-2003, 02:31 PM
willys36@aol.com's Avatar
willys36@aol.com willys36@aol.com is offline
Wiki Edits: 21
Post
I paint mine (the few I don't powder coat!) in catalyzed base/clear coat urethane like I use on my car bodies and it holds up like a champ! Only place it may give you problems is on the intake manifold @ the exhaust x-over. MUCH better than any rattle can finish you can get and you can match the car exactly. As with any paint, the finish is as good as the preparation underneath but with the usual basic prep, you will get a ceramic coated-like finish.
